My rear window wiper blade does not sweep the back glass, all I hear is a "thump,thump,thump. when I turn it on at the dash switch. I removed the arm and the motor is turning the blade, but the blade wont sweep the glass. Went to the junkyard, replaced the blade and still does the same thing. The gear on the motor doesn't look like it's worn,but I believe it's possible. Do you think I need to replace the whole motor or try to put Teflon tape on the gear or duct tape to see it this works to hold the wiper arm more tighter or just buy a motor? the motor looks like this will be a pain to remove and are not cheap. What would you do on this issue?
May 8, 2020 at 12:24 PM
