Rear Window replacement
1993 PONTIAC SUNBIRD
140,000 MILES • 1.2L • 4 CYL • FWD • AUTOMATIC
DANIEL MCKIM
Hi, i shattered my back driver side window on my car, it is the roll up kind not power motor. if i got a glass from junk yard what are the directions step by step how to take off door, take out any pieces of broken window and put new window in and door back on by myself?
Nov 1, 2016 at 11:43 AM
HMAC300
  • 48,601 POSTS
we have no pictures for that but you do not need to take door off. remove door panel there may be screws through arm rest and clips to hold panel on. clips for window handle as well you may rent a tool from auto parts. do not lose clip. then unbolt window from regulator when it is down what is left. you may need to unbolt window guides to install new one put new one in and hook up to regulator, but be careful how tight you make it as you could break new window.
Nov 1, 2016 at 1:33 PM
