rear wheel noise
2005 FORD ESCAPE
220,000 MILES
CHRISTI HEUTON
Humming sound from right rear area.
Jun 1, 2017 at 1:35 AM
STEVE W.
  • 15,113 POSTS
Wheel bearing or bad tire would be my first two choices. Jack it up, reach in and grab the spring, now rotate the tire. Most of the time a bad wheel bearing will cause the spring to vibrate even if the bearing seems tight. You may also hear the bearing when you spin the tire.
Jun 1, 2017 at 1:40 AM
