Rear view camera not working
2014 MITSUBISHI PAJERO
69,000 MILES • 6 CYL • 4WD • AUTOMATIC
SCOLE19
I replaced my battery last week. As soon as I did the rear view camera has stopped working. It shows the bluetooth searching when I put it in reverse, but it will give up and then turn off each time. I used your site and found it may be a fuse- but none of them are labeled as CRT or rear view camera. The ones I pulled (7.5amp) all seem to be fine. I also reset the radio since they are intertwined, but that did not change anything. Do you know which of the fuses in the Pajero is connected to the rear view camera? Are there any other things I could troubleshoot?
Thanks!
Nov 29, 2019 at 5:38 AM
This sounds like the system needs to be reconnected or reset. Unfortunately it appears this requires a scan tool. While we don't have a service manual for your specific vehicle I found a few people online that had the same issue. After a battery replacement the camera stopped working and the dealer was able to correct it. There is not much detail about what they are saying the correction was but it seems like they were able to re-establish the connection between the two.
Nov 30, 2019 at 5:07 AM
