I replaced the bulb because the car display was showing to "check left rear turn signal" - realized it wasn't flashing. After replacing the bulb no change. I am trying to find which fuse (either interior or under the hood) is the correct one to replace in the case that that is where the problem is coming from. Tried using this: https://fuse-box.info/volkswagen/volkswagen-tiguan-2008-2017-fuses-and-relay#Instrument_Panel
to find it on the diagram but it doesn't list rear turn signal.
Dec 19, 2021 at 8:20 AM
