Rear turn signal
1990 GMC C1500
194,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
ALWYSWRKIN
  • 6 POSTS
When I use my turn signal to turn left I get the fast blink like a bulb is out. So I replaced it. All other bulbs are working fine. I cleaned the socket really good, put new electric contact grease and still nothing. It is not blowing the new bulb but the one that was in it was blow. Tried the hazards, same thing but no fast blink. Just not flashing.
Oct 29, 2018 at 8:50 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
This is confusing. You say it flashes fast but then again you say it does not even work. So what do you mean?
Oct 29, 2018 at 9:56 AM
ALWYSWRKIN
  • 6 POSTS
Sorry, it does not work at all. Like a bad bulb. I have tried several new bulbs and nothing. Have you ever seen when it is the taillight assembly where the connector plugs in?
Oct 29, 2018 at 10:38 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Use a voltmeter or at least a 12 volt test light and test in the empty bulb socket for voltage with the lights on. If there is no voltage, test the supply wire for voltage at the next accessible spot going back toward the turn signal switch. If there is voltage though, then check the ground wire for being loose, etc. It could be the taillight assembly if the empty socket has no voltage, but the wire just before the assembly has voltage.
Oct 29, 2018 at 11:03 AM
ALWYSWRKIN
  • 6 POSTS
I tested every thing with a test light and it has power to the assembly. With a test light now. I cleaned and replaced the nut and bolt for the ground wire and I even removed the spaghetti mess trailer light harness that was spliced into the stock harness. So now it will not flash the bulb in the assembly but if I tap into the plug going into the assembly it will flash the test light but it is a fast flash. Passenger side everything is fine. Now why would it fast flash the test light?
Nov 5, 2018 at 12:15 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Usually it will flash fast if something is shorted out cause. Since you are getting voltage to the taillight assembly it does sound like you are correct, the taillight assembly is at fault.
Nov 5, 2018 at 7:02 AM
ALWYSWRKIN
  • 6 POSTS
Thanks.
Nov 5, 2018 at 9:05 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
You are welcome!!
Nov 5, 2018 at 9:16 AM
ALWYSWRKIN
  • 6 POSTS
I will get back to you with the results.
Nov 5, 2018 at 9:25 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Okay, thank you.
Nov 5, 2018 at 10:20 AM
ALWYSWRKIN
  • 6 POSTS
Sure enough, it was the circuit board. I included what was left of the metal contact tab that was attached to the curcuit. Looks like corrosion got to it until it eventually shorted out. I disassembled it to see what actually happened.
Thanks again
Nov 5, 2018 at 11:27 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
You are welcome.
Nov 6, 2018 at 6:46 AM
