Rear transmission mount part number needed
1984 NISSAN 300ZX
88,077 MILES • 3.0L • V6 • 2WD • MANUAL
ZX3001984
Unable to source correct part. 3 tries all wrong. Does anyone know the correct part number?
Sep 11, 2020 at 3:45 AM
Good morning,
I attached a picture for you to view.
Does it look correct? If not, can you post a picture of the mount you have? Check out the diagrams (below). Please let us know what happens.
Sep 11, 2020 at 4:10 AM
To replace mount, go to the back of the transmission. release the 2 bolts holding the mount to the crossmember. Then you need to raise the back of the transmission off the crossmember.
Use a floor jack to move it up and hold it. Then release the bolts holding it to the transmission and remove the mount.
Reverse the process to install.
Dec 17, 2020 at 3:03 PM
