Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
F-150
Tires
Replace/Remove
Rear tires will not move
1995 FORD F-150
130,000 MILES • 5.8L • V8 • 4WD • AUTOMATIC
KERRY GANN
MEMBER
FOLLOW
We changed the rear U-joint, now back tires will not move.
Sep 19, 2017 at 10:41 AM
MIKE H R
CERTIFIED EXPERT
make sure the alignment of the u-joint. make sure the car is in neutral. in park they would not turn.
Sep 19, 2017 at 1:43 PM
KERRY GANN
MEMBER
Thank you.
Sep 19, 2017 at 2:17 PM
CERTIFIED EXPERT
Do both rear tires not turn? Is the ebrake on? I was thinking you may have too long of bolt in the pinion flange?
Can you send a picture of the flange with the drive shaft bolted up please?
Sep 20, 2017 at 12:56 PM
