I bought new replacement rear LED tail lights. Hook both up and no running lights on passenger side. Driver side all works. Everything else works, turn signal, brake light just no running light on passenger side. I checked the running light wire and driver side was 11.4 volts and passenger side was 4.6 volts. Would that cause the light not to light up or is it just the LED lamp bad?
Thank you.
Thank you.
Feb 4, 2018 at 7:14 AM
