Replacing the rear shocks?
2004 FORD F-450
194,424 MILES • 6.8L • V10 • 4WD • AUTOMATIC
SAM MUSSELMAN
  • 36 POSTS
My truck listed above is a dually bucket truck and I’m replacing the shocks in the rear. Do I need to jack up the vehicle or can I replace them without lifting it?
Oct 12, 2022 at 1:46 PM
Hi Sam,
You can replace them without lifting the truck. When you install the new ones, you will need to compress them by hand to allow them to fit into position, but that isn't hard to do.
Here is a link that you may find helpful:
https://www.2carpros.com/articles/replace-shock-absorber
I attached the directions specific to your vehicle below. Note it says to lift the vehicle and then support the axle with a jack. In your case, the lack is the ground. LOL That is a lot of vehicle to lift. LOL
Let me know if this helps or if you have questions.
Take care.
See pics below.
Oct 12, 2022 at 8:12 PM
