I'm replacing the 2 rear main seals. I did it 2 years ago but somehow a leak again. I wanted to know if offsetting the seals 3/8 of an inch is a better way to do it. With black RTV at ends at where bearing bolts up at to.
And is it okay if i could only get the 2 bolts to 80ft lbs, vs the recommended 85?
And is it okay to use black RTV at mating surface of oil pump.?
And what's the torq on oil pan, ft lbs?
How does the bearing look?
Any other suggestions are appreciated.
Sep 23, 2023 at 8:15 PM
