The prop shaft, also known as a drive shaft, is the bridge between the transmission and the differential. Have you checked to see if it is turning when the vehicle is in gear?
Also, if it would have broken, it likely would be on the ground at one end. For some reason, this model isn't listed in my manual. But let me know what you find when checking the driveshaft and I'll try my best to help.
Here is a link you may find helpful. It explains in general how to remove/install a drive shaft, you may need to remove and inspect it for damage.
https://www.2carpros.com/articles/how-to-remove-a-drive-shaft
Jul 28, 2022 at 10:08 PM
