back of cab 3rd brake light and all lamps forward normal. rear turn signals normal. replaced LED bulbs no fix. ckd harness grnd at left rear frame good. replaced brake switch at pedal. replaced multifunction switch at column. ckd 2 under hood brake light fuses position 12,13 good. ckd park lights fuse position 22 at passenger kick panel (smart junction box) good. ckd main harness connector under hood LH side for tightness. wiggle, unplug plug back in all connectors to multifunction switch. most interesting symptom tail bulb will flash on then back off at brake pedal release. guessing if SJB or GEM needed reprogrammed other intermittent interior symptoms would exist but not the case. all interior cluster and dash features ok.
Aug 4, 2019 at 11:39 AM
