Rear main seal installation, what kind of lubricant should I use?
2001 SUBARU LEGACY
200,000 MILES
BASHWHEELS
Can you please tell me what kind of lubricant I should use when installing the new rear main seal? A lot of suggestions online say to use oil, and some say to use grease. A lot of back-and-forth so it has me skeptical what is the right way to go.
Sep 22, 2024 at 1:47 PM
When you install it, use the same type of engine oil you use in the engine. That is all that is needed.
If you look below, I attached that section from my manual.
Let me know if this helps.
joe
See pic below.
Sep 22, 2024 at 9:02 PM
