rear blinker not working
2001 VOLKSWAGEN PASSAT
105,000 MILES • 1.9L • TURBO • 2WD • MANUAL
GARRITY0116
driver rear indicator not working the left side is ok and indicator runs nice and slow the right thinks it is in a disco ive changed the bulb and still nothing ive been told it might be an shorting problem and track the wire back to the connector and run a wire from the indicator to the connector but not knowing which wire I'm reluctant to do this without help
Mar 27, 2017 at 9:33 AM
Can you please check the front blinker to see if it is working, if the front bulb is out it will cause the rear bulb to blink fast.
https://www.2carpros.com/articles/turn-signals-blink-rapidly
Best, Ken
Mar 30, 2017 at 10:45 AM
