High idle, high fuel consumption, could be a sensor?
2008 PONTIAC G6
155,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
HOLLOHEARTS78
The rear makes a thumping sound when applying breaks only. Normal idle is close to 0. Now start up idle is over 1 and bogs itself down when temperature reaches third line. Will use almost two lines on gas gauge going 18-20 miles with highway speed of 55 MPH and in town at 30 mph for 5 of the 18-20. Some sensor has popped check engine light on with code saying a temperature sensor is too hot. The front driver tire had steel belts showing on the inside of tire. Oil is leaking out down front of engine from the oil filter housing gasket. Is there a better one I can replace faulty one with? All these things have me only car making me worry it will leave me stranded somewhere far from the little country town I live in with not one accommodation so traveling next town is only way to get parts before car stops working and food and gas and work. Please help me out with these problems. Thank you for your time and knowledge.
Jan 24, 2024 at 2:43 AM
We can help you, but we only handle one problem per thread, and you have listed three. So, we will handle the engine problem on this thread. Please start new threads for the other two problems. Can you please give me the code number? It sounds like the engine is overheating, can I ask you if you hear the cooling fan come on when the engine is hot? Also, when the engine is cold remove the radiator cap to see if the system is full of coolant. This guide and video will help us get started on fixing the problem:
https://www.2carpros.com/articles/engine-overheating-or-running-hot
and
https://youtu.be/GSE9skKnOgY?si=TrzqCGT-Uh2Qjy1T
Please upload pictures or videos in your response to the problem so we can see what's going on.
Jan 24, 2024 at 11:26 AM
