Spindle? I am not sure I follow which part you are talking about. Do you mean the axle shaft? I attached a picture pointing at the part I am talking about.
If this is what you are talking about, you do not have to remove the axle but the spline part at the end of it that has a nut holding it on the hub needs to be pushed out when removing the hub.
If this is not the part you are talking about, take a picture of it and I will get on the same page with you. Thanks
Feb 25, 2020 at 4:56 PM
