The blower fan stop today, the rear fan still work with both the front and rear controls. The front blower fan will not work. I suspected that it might have went bad as it was making louder noise than usual.
I did check the fuse for the blower (J15) I believe, it was still good.
I got a new blower and before removing the old blower I just plug the new one in. the new blower did not work either. I test the new blower by running it off the battery . everything work there too.
I replaced the blower motor resistor module that also did not fix the problem.
When I unplug the motor, the dark blue wire has twelve volt on it when the car is in the on position, and the fan selector is in any position other than off. with it plug in I do not see any voltage on the dark blue wire until the fan selector switch is in the off position.
I have even tried to jumper the blower fan out. I found the dark blue wire with yellow strip on the blow fan went to the resistor module. I unplug the resistor module and jumper the dark blue with yellow strip wire to ground and still nothing.
the only other thing that has me confused is that all of the wire diagrams show the resistor module with five wires. Mine has only four, both old and new resistor module.
Not sure where to go right now.
Thanks in advance for any advise .
Feb 27, 2021 at 9:53 AM
(Merged)
