Rear heat was not working, but it only blows cold air. Replaced HVAC module with same results. Manually turned the actuator and heat worked, but every time i turn heat off, actuator slides back to cold. Trying to see if i need to replace the actuator (and which one since there seems to be two). Thank you.
Jan 12, 2017 at 6:25 AM
