Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
F-150
Engine
Block
Freeze Plug
Replace/Remove
Rear freeze plug replacement instructions needed
2002 FORD F-150
200,000 MILES • 4.2L • V6 • 2WD • AUTOMATIC
STEW76706
MEMBER
FOLLOW
i had a leak between the transmission and motor. To replace freeze plugs can i just scoot the transmission back a few inches. Easiest method?
Mar 5, 2022 at 1:20 AM
CERTIFIED EXPERT
Good morning,
You will need to move it back about 10-12 inches. The flywheel will have to be removed and then you have access to the core plugs.
Use two long guide bolts on the transmission for walking it back to support the transmission.
Mar 5, 2022 at 1:30 AM
