Yes, but it's helpful to have some special tools. Some other brands used a one-piece round seal. It was a rubber lip seal in a metal ring. To get those off, you had to separate the engine from the transmission, then remove the flex plate or flywheel. Chrysler used a two-piece rope seal. Remove the oil pan, then the rear bearing, and you'll see half of the seal in the bearing cap. You might be able to use a small needle-nose pliers to grab the end of the half that sits above the crankshaft journal, then push on the other end with a blunt tool like a small punch.
The special tool for installing a new rope seal is a "Chinese finger" type of tool that is placed around the end of the seal, then that tool is pulled over the crank journal first, then the seal gets pulled in with it. The seal is long enough to pull all of the tool out, then you cut off the excess rope.
You can also get a two-piece rubber lip seal for Chrysler engines. You might be able to slide the upper half in by pushing on it, but be sure to oil it first. A better option would be to use Silicone Spray Lube on the seal. We didn't have that stuff in the '70s. That makes rubber parts slide onto metal parts real easily.
Jun 28, 2019 at 5:58 PM
