Rear end ratio change
1964 CHEVROLET IMPALA
100,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
BEZZELLHOTMAILCOM
I have the car listed above with a power glide transmission with 1969 nova 350. I am running 3,200 rpm's at 70 mph. Would like to be running 2,000 at 70 mph. What ratio do I need to change in my rear end to achieve this? Or will it lug on take off?
Jul 31, 2019 at 9:17 PM
STEVE W.
  • 15,113 POSTS
Welcome to 2CarPros. The "common" rear ratio in the 1964 Impala with an automatic was 3:36 - 1 . There was a 3:08 as well that came behind a P-Glide. That is about as tall as you would want to go really. To drop the amount you want isn't possible with the power-glide. You might be able to get a bit closer if you swapped an OD transmission like a 700R4 into it.
Jul 31, 2019 at 10:19 PM
