Thumping/clicking/rubbing/roaring sound coming from the rear back of my car?
2000 FORD MUSTANG
193,000 MILES • 3.4L • V6 • 2WD • AUTOMATIC
H.MULLINS
Okay, there is a thumping/clicking/rubbing/roaring sound coming from the rear back of my car. I have had the back driver side wheel barren and axle seal replaced. The problem seems to still be getting worse. Please help.
Oct 10, 2022 at 1:16 PM
Do you feel the thumping or any of the symptoms in the vehicle? Did this issue start when the work was done on it?
As far as the noises are concerned, can you record what you are hearing and upload it for me to hear? Also, is there anything that you do that changes the sounds? For example, if you press the brakes or make a sharp turn does the sound change?
Let me know. With all that you mentioned above, it opens a lot of possibilities.
Oct 10, 2022 at 7:51 PM
