My window wouldn't roll up so cut the regulator cable so i could manually push up the window until I could get the motor replaced. I then replaced the window regulator and motor yesterday with brand new parts only to discover that the new motor does not roll up either. Pulled a switch from the passenger side to see if the switch was the problem but that switch also did not roll window up, only down. Motor attaches to a 2 prong pigtail connector so I tested voltage with multimeter. 11.7 one direction -11.8 other. If I reverse the wires the motor will reverse. So that voltage is without motor attached in circuit. If I measure with motor attached I get 7.62 volts one direction and -.02V the other direction. i should add multimeter was hooked up with red prong to one wire on pigtail and black prong to other wire on pigtail.
Jul 3, 2021 at 2:03 PM
