My rear rotors were replaced at a shop last year; in learning to repair the van myself, I discovered that the driver's side rotor was misaligned when it was put back on, and currently the access port is partially blocked and I do not think I can access the starwheel through it.
The parking brake needs adjusted (it is weak), which is how I discovered this problem. Many other errors were made by that shop, which I have been able to fix, but I am unsure how to proceed to remove the rear rotor in this situation.
The wheel can rotate, a bit, and I have not yet tried to use the screws to "push" the rotor free, as those holes in the rotor are, of course, also misaligned, and the pressing bolts will only have a partial surface to push against. Help? Thanks!
Oh, I am a complete novice, but I learn fast, and in the last month have successfully repaired the air intake/filter, cleaned the mass airflow sensor, cleaned the throttle/throttle body, replaced the PCV valve, replaced the thermostat (lots of parts removed/replaced), bled the cooling system, replaced the front brake pads and rotors, cleaned/lubed the calipers, and bled the brake lines.
I follow instructions to a T, and am enjoying all this. Except the part where someone put Loctite on the lug nuts of three wheels, and something that turned into a rigid, sticky silicone inside the rear caliper pins instead of lubricant or anti-seize - pins could not move, so rear brake pads had actually rusted in place. So much cleaning.
Oct 21, 2018 at 5:59 AM
