I took my car to get serviced at the CarMax dealer due to a rubbing/grinding noise when turning. The technician diagnosed the problem/noise coming from the rear differential after going on a test drive. The technician stated when the fluid gets dirty and doesn’t get changed the differential will make that noise. Well they told me they will drain and fill the rear differential fluid and add friction modifier. It’s been 6 days since and the noise still sounds about the same. Should I be concerned or should I just keep waiting until the fluid soaks into the gears?
Jan 13, 2020 at 9:24 PM
