The only place to come when you need a problem solved correctly is here. money or no money, which puts you far and away the beat. I just got the car listed above it is a drop top, cherry. I opened the rear deck using the button on the dash,nothing. so I then pushed the picture on the key chain that came with car it opened. when finished I closed the trunk thinking it latched got in car fired her up down the road. I went I hear a ding like set belt not on it s on. I hear it again looking at dash below speedometer rear deck spelled out. I pull over go to close it tight jump in light still there. I try again little harder and it will not secure. I have messed around with it it does not appear that anything broke the white plastic piece that moves when pushed on key chain moves, but trunk will not latch. is there a way to fix?
Mar 15, 2017 at 1:35 PM
