Thanks for getting a new post started.
Sorry for the confusion I said on the last post. I think I said you have to remove that flange. However, now that I look at it again, that is the crank flange, and it does not come off.
Here is a guide that will detail how to do this. It is on a different vehicle, but it is almost identical to your vehicle.
https://www.2carpros.com/articles/crankshaft-main-seal-replacement-rear
It looks like you still have the two bolts that come up through the pan installed so you are going to have to remove those.
The manual does not have a process on this seal so we are going to have to use this guide, but it will walk you through this except for the fact that you do not need to remove the seal and reuse the housing.
Let's run through this and let me know what questions you have.
Thanks
Apr 28, 2022 at 11:43 AM
