Rear driver side drum removal
1995 OLDSMOBILE 88
168,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
AHARTLEY
  • 118 POSTS
I can't get the rear driver side drum off to check the brakes. The passenger side came off with no problem at all. I've tried tapping on the drum with a hammer to work it off. Years ago there was a way to work the adjusters loose on a car by an opening on the backside of the assembly however on this I'm not finding one. It's been "a day or three" since I've done this.
Jan 7, 2021 at 1:31 PM
Yes, they can be stuck on pretty well, is the drum loose and the axle and wont come of or stuck on the axle? if so this video should help us.
https://youtu.be/UV0kfP17Co0
Jan 8, 2021 at 6:08 PM
AHARTLEY
  • 118 POSTS
I will be trying this tomorrow. I have tried the hammer on the drum with no success. I'll try it with the WD-40. Thank you.
Jan 8, 2021 at 7:09 PM
