Factory torx head on the top of the rear caliper for removal needed
1995 BUICK RIVIERA
42,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
TRAIN-M
What size is the factory torx head on the top of the rear caliper for removal?
May 29, 2020 at 7:13 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
The sleeve bolt is on the bottom to remove the rear brake caliper.It is 13mm. After removing the sleeve bolt pull the caliper up off the brake pads and slide inward to remove.Are you removing to change the brake pads? I've attached a picture below for reference.Hope this helps and thanks for using 2CarPros.
May 29, 2020 at 9:03 PM
