Released cable at center vehicle cable adjuster.
Removed disk calipers and brake drum.
Removed old brake shoes. Cleaned area & drum
Fitted new shoes, drums, disk calipers and wheel, leaving one nut out for adjusting shoes.
Adjusted until wheel could not be turned then backed off three turns.
Adjusted hand brake cable to manufacturers specifications.
Reversed the vehicle up driveway and applied handbrake to maximum and vehicle slowly rolled down driveway. Repeated process with the handbrake applied fully, same result.
Any clues?
Any clues?
Nov 16, 2019 at 6:43 PM
