Rear brake self adjusters release
2003 MAZDA PROTEGE
134,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
RON MOLLOHAN
The drums are worn to the point that I cannot get them off over the shoes. I cannot see how to release the self adjuster so I can get the drum off.
Jun 25, 2019 at 5:45 AM
Welcome to 2CarPros.
The rear brake adjuster on these vehicles are different that the traditional type. These have a ratchet type which are not accessible from the outside. So, here is what I suggest. First, make sure the retaining screws are removed from the outside of the drum. There are two and they should be a number 3 phillips. Next, make sure the parking brake cable is loose.
Then you will need to smack the drum between the wheel studs. Don't be afraid to hit it with a heavy hammer. See if that loosens it. Then tap around the outside diameter of the drum. (See picture 2)
I attached an exploded view of the brakes (picture 1). I circled the adjuster.
Also, here is a link that may help. There is a video in it that explains what to do with a stuck brake drum.
Let me know if this helps.
Jun 25, 2019 at 10:28 PM
