Someone must have replaced the socket with the wrong style. You're describing the older 1157 bulb with the round, brass base. Even my '88 Grand Caravan already had the newer 3157 with the flat plastic base.
There's something else you're overlooking. A bulb can't burn out right away unless the system voltage is much too high, but then all the other bulbs would do the same thing. What you need to do is look closely at the bulb to see how it failed. If the filament is indeed burned out, my guess would be you're installing used bulbs. While this is a stretch because I've used old bulbs all my life in my vehicles, I've only run into this with sealed-beam head light bulbs that I saved from scrapped cars. It seems they must suffer the same fate as tv picture tubes that sit for a long time without being used. I suspect air seeps in. That will cause the bulb's filament to burn through in short order.
If you're simply running into multiple bulbs that stop working, a better suspect is corroded contacts in the socket, or wires that are corroding apart. A more elusive problem is when one of the contacts had a little corrosion, and that caused heat to build up when current flowed through it. That can cause a contact in the socket to melt into the plastic disc it sits in. Spring pressure will cause that contact to drop down, and it may only work when you push down on the bulb. A clue to this is to look at the two contacts on the bulb. Those are solder, and if those contacts got hot enough to melt the plastic disc in the socket, they got hot enough to melt away the nice rounded center of the bulb's contact(s).
Besides excessive voltage, excessive vibration will lead to early bulb failure. If a replacement socket doesn't fit snugly in the housing, it can bounce around. That will shake the filament until it cracks. You have to look very closely to see that crack. It usually shows up when you tap the bulb. That type of failure is quite different from one that burned out from age or excessive voltage. Those will have a tiny ball of metal on each end where the filament broke, the gap will be much bigger and easier to see, and there may be black areas on the filament or on the glass.
If you see white powder inside the glass, that is due to the entry of air. During manufacture, they put a powder in there, then explode it to burn off any residual air. That leaves a mirror or shiny-looking spot somewhere out of normal sight. That residue is what turns into that white powder if air gets in.
Feb 27, 2021 at 1:58 PM
