After having the rear brake cylinder replaced the brakes barely work and the brake pedal goes to the floor
1999 PLYMOUTH GRAND VOYAGER
200,568 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
MSNY
  • 4 POSTS
I recently had my passenger rear wheel cylinder changed because it was very bad and leaked. Now since having it replaced my brake pedal goes all the way to the floor and barely wants to stop. What's wrong?
Jul 9, 2019 at 11:56 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Just a few questions first. Were the repairs performed by a shop or yourself? Was the brake system properly bled? Here are a few tutorials for you to view about low brake pedal and brake bleeding:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Hoping to hear back soon.Hope this helps and thanks for using 2CarPros.
Danny-
Jul 9, 2019 at 4:00 PM
MSNY
  • 4 POSTS
Hi. The repair was not done at a shop, nor was the lines properly bleed. I did go to a shop and get that done and was told I have to replace the rear brake line.
Jul 9, 2019 at 4:05 PM
MSNY
  • 4 POSTS
Also After getting the cylinder replaced it was still leaking brake fluid as the mechanic was bleeding the line.
Jul 9, 2019 at 4:07 PM
DANNY L
  • 5,648 POSTS
Hello again.
Well that that explains why your pedal is all the way to the floor.You will need to have the line replaced and have the system completely bled to have your brakes return to normal.Hope this helps and thanks again for using 2CarPros.
Danny-
Jul 9, 2019 at 4:38 PM
MSNY
  • 4 POSTS
Thanks.
Jul 9, 2019 at 5:03 PM
DANNY L
  • 5,648 POSTS
You're welcome ! Let us know the out come. Hope you will use us again in the future and thanks again for using 2CarPros.
Danny-
Jul 9, 2019 at 5:12 PM
