Rear axle bearing replacement
2006 GMC YUKON
230,000 MILES • 5.6L • V8 • 4WD • AUTOMATIC
SHERIFF31
I am replacing the rear axle bearings and seals (out side by brake assembly not in the differential). I replaced them about 1,000 miles ago and the new ones failed. Inside the bearing housing is a plastic sleeve and some type of seal that allows the differential oil to lubricate the bearing. What is that part called and how can it be replaced? I am not finding anything regarding this online. Thanks
Mar 28, 2018 at 9:23 AM
Good afternoon.
Are the bearings pressed into the differential or pressed on the axle?
Mar 28, 2018 at 9:59 AM
SHERIFF31
They are pressed (actually they are set with a set tool and hammer) into the housing(differential)the axle is a separate piece that comes out before I can even remove the oil seal.
Mar 28, 2018 at 11:24 AM
Okay, thanks
If they failed again, I would look hard at the axle where the bearing rides. they wear a lot and you end up with up and down play even after the new bearing and seal are installed.
Mar 28, 2018 at 11:29 AM
