The power door lock on the passenger side barn door is dead. It does work manually and all other locks function normally. I've replaced the actuator and checked fuses, but not the lock and unlock relays. Also there doesn't seem to be power getting to all the roof contacts which energize/de-energize the door lock. I know the location of the relays. Should I check them first? Also, how do I test the roof contacts?
Thank you, Scott
Thank you, Scott
Jan 24, 2019 at 8:44 AM
