Hello, when my truck is lifted off the ground, there is about 1/4 inch play when I push and pull on the rear tires. I was told that the C clips inside the differential that hold the axle shafts in place may be worn and need to be replaced. Practically every time I go over a bump, there is a pretty loud noise from the rear. Am I on the right track? Should I also change out the bearings and seal while I am at it?
Aug 20, 2019 at 2:49 PM
