Most likely not as long as I understand the progression of this. Was it working properly and then it stop rising and you found an airbag issue? Were the bags leaking or were they replaced as a "guess" at what is wrong and it didn't change anything?
Normally what happens is when there is a leak in the bag or line is that the pump runs and runs trying to continually keep the vehicle at the correct ride height. By running this much it burns the pump up and then the issue is noticed because it is dropped down.
The airbag or leak is fixed but the pump keeps running because it can't build the pressure. So if the pump is running and there are no leaks then the compressor is most likely the issue.
Jan 10, 2021 at 3:44 PM
