I show the front blower motor and the rear motor available. The one in the console is not listed as available. That is at a few different suppliers.
Remove the liftgate door opening weather seal.
Remove the liftgate scuff plate from bottom of rear liftgate opening.
If equipped, remove the third row seat.
Remove the rear header garnish trim panel. (pic 1)
Remove rear door scuff plates. (pic 2)
Fold down the second row seat.
Remove the cross car scuff plate. (pic 3)
Lift trim covers off of second row safety belt anchors on B pillars.
Remove Anchor nuts. If equipped, repeat for third row safety belts.
Remove second row safety belt lower nuts.
Remove the rear door opening weather seal.
Remove the C pillar upper trim panel. (pic 4)
NOTE: Remove the lower hook attached to quarter trim panel, followed by the top attachment, and then the lower rear attachment.
Remove the D pillar trim panel. Remove the liftgate door opening weather seal.
Remove 2 screws and one pushpin. Remove the quarter trim panel. (pic 5)
To install, reverse removal procedure.
Aug 5, 2018 at 11:36 AM
