Rear A/C control temperature button not working
2002 TOYOTA SEQUOIA
130,000 MILES • 4.7L • 2WD
KEVIN OSBORN
All other buttons work on rear A/C control panel, I just can't turn the A/C temperature down.
Jul 8, 2022 at 3:32 PM
If the panel lights up but there is no control over the temperature it is usually the control module, unless the temperature inductor goes down, but the temperature stays the same then it will be the rear temperature blend door actuator. Here is how you can change out the rear control module in the diagrams below. Check out the diagrams (below). Please let us know what happens.
Jul 9, 2022 at 8:53 AM
KEVIN OSBORN
I was thinking I'd have to replace that. Everything else works fine. So, it's called the rear control module?
Jul 9, 2022 at 9:57 AM
Yes, rear HVAC control module.
Jul 9, 2022 at 12:43 PM
KEVIN OSBORN
Thank you, sir. I'll let you know how it goes when I replace it.
Jul 9, 2022 at 1:55 PM
Please do.
Jul 10, 2022 at 1:19 PM
