ready light does not come on?
2005 TOYOTA CAMRY HYBRID
90,000 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
CHRIS PINNOCK
  • 15 POSTS
The 10-amp gauge fuse does not have power, this is not a problem with instrument panel. none of the power windows work etc. If I jump power directly to the fuse everything works, and the ready light comes on and engine will start. I have removed the dash and facia to get to all the wiring to check for wiring issues. Secondly the battery and accessory wire to the ignition have no power even with ignition turned on and engine running. I have to point out that my vehicle is a Toyota Alphard Hybrid 2.4 2005, but you do not have this vehicle in your selection list. I have added a photo of how deep I have gone to try and solve this issue. Yes, I know how to put everything back together as I am a competent DIY mechanic.
The fault codes from Tech stream are as follows.
1 P1780 Shift position sensor (Already sorted)
2 P3108 Communication Malfunction (A/C ->HV)
3 Communications malfunction (Brk ->HV)
Sep 27, 2023 at 1:41 AM
With these trouble codes it looks like one of the control modules is not working, I would try a computer system reboot. Please follow this guide to proceed:
https://www.2carpros.com/articles/step-by-step-guide-performing-a-hard-system-reboot-for-your-vehicles-electronics-systems
Also, I would check the fusible links this guide can help, and I have included a wiring diagram so you can see which links to check.
Sep 28, 2023 at 10:33 AM
CHRIS PINNOCK
  • 15 POSTS
Hi Ken thanks for your reply, I have done most of the things suggested and shown in the videos. I am next going to change all fuse able links, plus today I traced two wires from the ignition switch that have no power at the ignition switch end. one is labelled battery the other acc. Those two IO will be doing tomorrow Friday 29th. I will let you know how I get on. Kind regards, Chris
Sep 28, 2023 at 11:10 AM
Okay, let me know what you find.
Sep 28, 2023 at 12:39 PM
CHRIS PINNOCK
  • 15 POSTS
Hi Ken,
Update: The only problem I have left now is the gauge fuse still no power. traced wires and have not found any breaks or burnt out wires. I need to find what gives the gauge fuse power. With this being a Hybrid so the usual suspect (connector to starter) is obviously not the supply point having no starter.
Sep 29, 2023 at 2:18 PM
I see an accessory relay that I would check or swap out. This relay should be inside the vehicle in the interior fuse panel.
Oct 2, 2023 at 9:29 AM
CHRIS PINNOCK
  • 15 POSTS
Hi Ken, sorry weather has been awful here, not been able to do much. I have checked all the relays on the driver's side, and they are fine. I will check the passenger side fuse and relay box in the next couple of days. Having gotten hold of the wiring diagrams, that was my next job.
I will try tomorrow and let you know how I get on tomorrow evening.
Kind regards,
Chris
Oct 2, 2023 at 9:54 AM
Sounds good, hang in there, the weather will let up.
Oct 3, 2023 at 10:19 AM
CHRIS PINNOCK
  • 15 POSTS
Hi Ken, yeah I have been finalizing the re-route of all my accessories which I could do in the vehicle. Fri-Sun looks good weather wise so that's when I will be doing the passenger side fuse/relay block. I have to have passenger door wide open as the box is under the footwell and the only way to get to it is being a contortionist lol, being disabled these jobs take me 4-5 times longer than an able-bodied person. But I am not a quitter. I'm amazed with what I have achieved so far. I will keep you updated on progress.
Kind regards,
Chris
Oct 3, 2023 at 10:29 AM
Yep, we keep going no matter what, good to hear you don't let anything get you down. Please let me know what you come up with.
Oct 4, 2023 at 7:57 AM
CHRIS PINNOCK
  • 15 POSTS
Hi Ken,
I took delivery of a xtool D7 diagnostics unit today, I know a bit over the top for a DIY'er but I love my gadgets. It seems there is a correlation between the ignition system and one of the ECU's (low power) Lights I am getting on dash i.e. Skid control, ABS, Parking brake, etc., etc., etc. So, looks like that fuse box and relays may be the culprit. One of the things I am over the moon about is the Hybrid battery is great 100% pass. Now the issues could just be bad fuse/relay or corroded contacts around that junction box. Sorry I am very clinical and methodical, so I speak what I am thinking out of the box here. Its Dark now so calling it a day. Will let you know all fault codes etc., tomorrow night. Take care, speak soon.
Kind regards,
Chris
Oct 4, 2023 at 11:29 AM
Hi Chris,
The scanner will help with any cars you have or friends' cars to help fix them, so it is a welcome addition to the toolbox. Let me know how it goes.
Oct 5, 2023 at 8:11 AM
CHRIS PINNOCK
  • 15 POSTS
Hi Ken, I am just waiting for the delivery of new relays, it could be 19th before they arrive. In the meantime, all dash put back, Hybrid battery cooling fan checked. Inverter cooling pump replaced. I will message you after the new relays arrive.
Kind regards,
Chris
Oct 9, 2023 at 5:08 AM
Sounds good, we would like to see you fix the problem and are here to help.
Oct 9, 2023 at 8:59 AM
CHRIS PINNOCK
  • 15 POSTS
Hi Ken,
The relays came early, and they have been fitted, yet still problems. Still no power at the Gauge fuse so Hybrid won't go into "Ready" mode. Although a lot of issues have now been solved, I seem to have a really puzzling issue with the ABS system. I get reports that all wheel sensors are in error state, the yaw etc., etc., etc. If I jump 12v direct from the battery to Gauge fuse Vehicle goes into "ready" mode and vehicle will start. I have checked all fuses and relays and replaced any that I was not sure about. it's really starting to get me down now. I know that a issue with the braking system can throw all sorts of codes up, but why would the ABS suddenly go faulty so badly when the day before it was fine and a blown accessory fuse later and all goes downhill. (blown fuse was caused by previous owner putting a 10-amp fuse connector into roof monitor and not sheathing wires properly) this fell onto metal body part in roof area and blew the fuse, after which all this mayhem.
Kind regards,
Chris
Oct 14, 2023 at 7:51 AM
Sorry, we only handle one problem per thread, please post your new question here, you must be logged in.
Oct 14, 2023 at 12:51 PM
CHRIS PINNOCK
  • 15 POSTS
Hi Ken, sadly all the issues I mentioned are related to the initial post I made. I won't be bothering you any further. Thanks for your help and suggestions so far, I could have put the full list of faults, but that would have in my opinion created more confusion. As I said previously, I am not a quitter so I will continue until I fix the issues. Take care, Kind regards, Chris
Oct 14, 2023 at 10:01 PM
Sounds good, can you please let us know what you find? I will be glad to help you, but we need to keep the post subject related, if you feel they are related I will be glad to continue helping.
Oct 15, 2023 at 10:52 AM
CHRIS PINNOCK
  • 15 POSTS
Hi Ken,
Yes, they are all related as they all happened at once. I have come a long way since I decided to tackle this job myself after being let down by a so-called specialist. These are the next jobs I intend to tackle:
1. Change the Ignition switch
2. Change the Gear selector lever and check selector cable.
3. check red/white wire from ignition switch to 10amp ST fuse in Engine Bay (no power at either at present) that's ST2 to ST fuse.
4. check white/lilac cable from ignition to (a) 30ampfuse engine bay that's the AM2 cable.
(b)white/lilac cable from ignition to 7.5amp fuse passenger side fuse block AM1 cable.
After studying wiring diagrams and tracing all wires I think that should fix all issues.
Kind regards,
Chris
Oct 15, 2023 at 12:11 PM
Excellent, it sounds like you have a good handle on it, if you need any instructions or help, please let me know. Here is how to change the lock/switch out.
Oct 16, 2023 at 9:22 AM
CHRIS PINNOCK
  • 15 POSTS
Hi Ken,
Thanks for the lock/switch advice. Having a good rest this evening then tomorrow I start on the list I sent. I will give you an update on sections completed tomorrow night.
Kind regards,
Chris
Oct 16, 2023 at 9:29 AM
You are welcome, please let me know.
Oct 16, 2023 at 10:04 AM
CHRIS PINNOCK
  • 15 POSTS
Hi Ken,
I think I may have totally over complicated the issue, I have changed every fuse and every relay in the vehicle and the issues remain. I have decided to take a step back and re-think the whole problem and would appreciate your honest opinion. This all started when a fuse blew in the roof behind a roof monitor. On tracing the wire from that I ended up at the ignition switch. two wires from the ignition switch that should go live in turn. The ACC and the On wires do not have any power these were what all the aftermarket accessories were wired to. I think that the power that went through these two wires was cut by the blown fuse because they were overloaded. I think all I have to do is rewire these two wires from the ignition switch to the components in the fuse blocks they go to by tracing the original wires through their connections. Please give me your thoughts on this. I have checked the wiring diagrams as I stated before and I know exactly where they go to and any connections they pass through.
Kind Regards,
Chris
Oct 23, 2023 at 2:13 PM
It sounds like a module is blown; I would do a CAN scan. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
https://www.2carpros.com/articles/can-scan-controller-area-network-easy
Here is a CAN scanner on Amazon for about $134.00 if you need it. They have cheaper and more professional units as well; this one is a middle of the road.
https://amzn.to/3ZYCA1P
Please go over these guides and get back to us.
Oct 24, 2023 at 8:05 AM
CHRIS PINNOCK
  • 15 POSTS
Hi Ken,
Thanks for the pointers, I can't afford the monthly fee for the Alldata program. Having said that, remember I said I had gotten hold of a Xtools diagnostics kit. On the system scan it comes up with a issue with the ABS. A lot of codes showing 13 in all. I am thinking that combined with the two wires from the ignition, this is what is causing my issues. I can't afford to buy a replacement ABS module just yet, but I think that will be my next step. I am going to check all the connections and grounds first, clean them up look for any bent pins and grease them.
If you disagree with that assumption, please let me know.
Kind regards,
Chris
Oct 24, 2023 at 1:13 PM
This can tell us what is going on with the system, so we don't replace parts that are unnecessary.
Oct 24, 2023 at 1:53 PM
CHRIS PINNOCK
  • 15 POSTS
The Scanner I have is for my Alphard Ken, Its a JDM import so protocol is JOBD.
The normal OBD scanners don't read the ECU'S properly. I can read all the systems Engine ECU, Powertrain, Hybrid battery etc. I can send you an image of the faults it is finding if that helps.
let me know.
Chris
Oct 24, 2023 at 2:08 PM
STEVE W.
  • 15,113 POSTS
FYI, Alldata and Mitchell1 both have DIY versions that cover a single vehicle for a one-time price. Mitchell 1 actually just changed theirs as well, it used to be that some topics were redacted in the DIY version, from what I have read that is no longer the case.
However, if this is a true JDM, the info may not apply very well as those can be quite different than the US builds. I believe that van uses a version of the first-generation hybrid drive similar to the Prius. As you stated, the US based scan tools can be difficult on them. Some of the Chinese tools can read JDM cars but even those can be flaky at times and any support outside the dealer networks in Japan on JDM vehicles is spotty at best. One of the biggest downsides of "Global" vehicles.
Oct 25, 2023 at 3:42 AM
CHRIS PINNOCK
  • 15 POSTS
Hi Steve, yes, I prefer Techstream for the JDM, but sadly I cant justify spending £1200 on the lead from the USA at present. Techstream is the perfect answer which I will be looking at further down the line. A lot is now coming together after Ken's input and basically late nights scanning through Toyota Japan's maintenance cdrom with google translate. As I told Ken, I am not a quitter, I will get there.
Kind regards,
Chris
Oct 25, 2023 at 6:19 AM
