Re-wiring tail/turn/brake lights
1995 PONTIAC TRANS AM
83,000 MILES
KOCHKIEL
Hi guys,I have bought the car listed above. I need to do some re-wiring of the tail lights because I live in Denmark, Europe and we have other regulations on how the turn/brake lights shall work.
Bottom line, I need to disable the brakelights from using the same wiring as the turn signals for the tail lights.
I have studied the wiring diagram, and I think that if I cut the light blue wire coming out from the brake pedal switch, then there will be no connection from the brake lights to the wires used for the turn signals to the rear end of the car.
Can anyone tell me if I am right or wrong, and hopefully tell if this will affect other things than just the brake lights?
Feb 18, 2018 at 7:42 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
You are correct, the light blue wire coming off the brake switch is for the rear brake lights.
Feb 18, 2018 at 7:58 AM
