wont go over 20 mph
1998 TOYOTA RAV4
158,000 MILES • 2.0L • 4 CYL • AWD • AUTOMATIC
JTL6096
  • 4 POSTS
The car starts right up (has check engine light on) and the transmission will go through the gears (when front an back of vehicle is jacked up). I do not think the transmission is bad, but when you take off it will go through first and into second gear, but instead of accelerating, it is like it goes back into a neutral state. The speedometer still goes up but the engine just revs. And when put in park it makes a noise like the park pin is not catching right an the vehicle will still roll in park. the transmission fluid looks and smells good. Could this be a transfer case problem or linkage or even a sensor?
Nov 6, 2016 at 3:21 PM
MHPAUTOS
  • 31,937 POSTS
Do you know what the codes are that have caused the check light to come on?
Nov 6, 2016 at 6:25 PM
JTL6096
  • 4 POSTS
No, I am going try an get it to the local garage to do that tomorrow. Will let you know then.
Nov 6, 2016 at 6:50 PM
Here is a guide that will help you do it yourself
Let us know what you find
Best, Ken
Nov 12, 2016 at 12:38 PM
