i noticed earlier last week that when i start my vehicle i hear a rattling noise kinda hard to explain unless you actually hear but car but when i start it it rattle for a couple of seconds and then i i put it in drive and i accellerate just a little to get my car to move it more rattling as well yet agin for a couple of second then it stops i went to a mechanic and they said i need to replace my tension pulley so i replaced that they said it would stop to rattling well it didnt so my husband looked at my spark plugs they were bad i replaced all my spark plugs as well as my valve cover gasket because i found out i had oil on my plugs luckily i found that out right when the leak happened i have plenty of oil in my car so we are stumped as to what my problem with my vehicle is i also had my motor mounts check out by 2 mechanic shops my motor mounts are fine they are suggesting get a diagnostic test unfortunetly i dont have 89 bucks to get that done do you have any idea what may be the problem
Sep 22, 2014 at 3:47 PM
