O man, that is not good, do not drive the car anymore, it sounds like you have a valve train issue like the camshaft actuator, balance shaft or a roller follower, you need to lift the hood and see if you can tell the area of the engine noise, front, middle, under or rear of the engine. That way we can pinpoint the problem, can I ask if the check engine light is on? If so we need to get the codes which can help as well. This video will help.
https://www.youtube.com/watch?v=LBCpCWEFnTg
Has any work to the engine been done recently? thanks for the videos they helped. Ken
Apr 15, 2026 at 7:45 AM
