Unfortunately, we need to separate these issues out into separate posts. The only reason we need to is because others will not find the answers to the other issues. So let's address the rattling noise here and get a new post started for the other issues.
The rattling noise is most likely an exhaust issue but I would not secure this to the body or frame. Your exhaust needs to be isolated by rubber hangers from the frame and body because it will vibrate and cause all sorts of other noise issues.
So the way to try and find this is to use a rubber hammer and hit the exhaust to see where it is rattling. If you can't locate it then it is most likely the interior portions of the converters or muffler.
Let me know if you have questions and what you find and we can go from there. If this does not sound right then can you get a video of the noise so we can get on the same page? Thanks
Aug 13, 2020 at 5:23 PM
