Rattle sound
2018 VOLKSWAGEN TIGUAN
35,000 MILES • 2.0L • 4 CYL • TURBO • 4WD • AUTOMATIC
TIGGIE
  • 7 POSTS
Rattle sound most of driving time when accelerating on lower gears, disappear between shifting and disappear on higher gears.
Apr 1, 2021 at 7:07 PM
This could be a number of things but could you get a recording of the noise so that we can get on the same page?
If this is only making the noise when you are pressing the accelerator at lower speeds, I suspect this is detonation. In other words it is spark knock. This is unburned fuel that is igniting at the wrong times.
If this is the case, the knock sensor should pick this up and adjust the timing or fuel so that it does not happen.
https://www.2carpros.com/articles/how-a-knock-sensor-works
However, if you have bad fuel then it may not be able to adjust enough.
Let's get a recording of this so we can e sure this is what it is. Thanks
Apr 2, 2021 at 7:20 PM
TIGGIE
  • 7 POSTS
Thank you for your prompt reply. I use mid-range fuel 98, the minimum recommended is 97. I attached two audio files.
Thank you
Apr 3, 2021 at 7:23 AM
Sorry but I am not picking out the noise. Does it make it at any specific time in the video?
Apr 3, 2021 at 8:08 PM
TIGGIE
  • 7 POSTS
Best part is the last 8 seconds from the first video. I tried to put a mic in the engine bay but couldn't not record the sound from there. Seems that the sound can be picked up inside the car only. It is kind of krrrrr. Rattling or rumbling
Apr 4, 2021 at 3:34 AM
Got it. Can you duplicate this by sitting still with the vehicle in park and just revving the engine?
That does sound a bit like an upper end rattle. Clearly it is muffled but that would fit with when you are hearing it.
However, if this is an upper end noise like a valve train noise, then you should be able to lift the hood and have someone rev the engine and pick it up.
Apr 4, 2021 at 6:47 PM
TIGGIE
  • 7 POSTS
Unfortunately the sound can't be heard while the car in park .. only while moving. Also last night I placed a mobile in the engine bay but unfortunately couldn't pick up anything. Also if windows are opened then I can't hear the sound.
Apr 4, 2021 at 7:42 PM
Have you noticed this getting worse? Is it a chance that this is normal? Have you owned this since new or did you just buy it?
What I would suggest is going to a dealer and asking to compare this to another vehicle with the same engine and transmission.
Apr 5, 2021 at 5:49 PM
TIGGIE
  • 7 POSTS
I bought this car as certified pre-owned since January 2021. And the sound was there since test drive. I tool the car to the dealership and they said it is normal. The only thing is that the sound not always there and if I'm driving too gentle on acceleration then the sound is not there.
Apr 5, 2021 at 6:09 PM
STEVE W.
  • 15,113 POSTS
It almost sounds like exhaust rattle from a hanger or pipe barely touching as the engine flexes. Similar to a heat shield that is loose on the body of the car.
Try this, pull up to a solid wall on the drivers side. Stop the car, put it in drive and hold the brake down, now rev the engine and see if you can make it create the noise and record that if it does it. Try the passenger side as well. Being this is a turbocharged car it could also be an issue with a turbine wheel bearing starting to fail under load.
Apr 6, 2021 at 12:08 PM
TIGGIE
  • 7 POSTS
Thank you for your prompt reply. I pulled up to a solid wall tried both passenger and driver sides rev the engine with brake applied and no sound. considering the the new Tiguans will not allow rev more than 2,000 RPMs while braking, I managed to stick a mic down the car beside the exhaust and recorded a sound clip trimmed it to contain the rattle only. The sound can be heard as if it is in the background of the sound clip.
Apr 6, 2021 at 5:02 PM
I agree with Steve that more than likely if it is not normal it is a turbo bearing beginning to fail. That makes sense with the idea that it does not do it on light acceleration because the turbo is not being spooled up on light acceleration.
Again, I am not convinced this is normal but I am also not sure that it isn't.
Apr 7, 2021 at 6:49 PM
TIGGIE
  • 7 POSTS
Thank you all folks, I will take an appointment with the dealer again and inform them. Is there a way I can check the bearing?
Apr 7, 2021 at 7:07 PM
STEVE W.
  • 15,113 POSTS
Not easily as it's inside the turbocharger. What you might want to do is take it to a different shop that didn't sell you the car and have them at least listen to it in person. They might give you an answer other than "It's normal" as they wouldn't worry about the warranty aspect of the repair like the dealership would.
Apr 7, 2021 at 7:12 PM
