I had a mechanic replace both cylinder heads at 106,000 miles due to cracked heads as it was losing coolant out the exhaust. They had the truck for two months due the issues which they eventually resolved. Well the very next day on a cold start up I noticed a rattling noise that lasted a few seconds. not a ticking noise. as if it was a timing chain dragging is the best i can describe it. I gave the truck back to them two to three more times which they had for extended periods trying to resolve the issue. it got to the point where I just gave up with them. Truck is now just shy of 117,000 and still has this issue. first cold start of the day it will do it and then usually fine rest of day. there can be a period of a day or weeks where it will not do it at all. really lost with this. not sure if this is something they did wrong or? just looking for some direction. thank you.
Feb 25, 2017 at 6:14 PM
