Only when I am in park or neutral do I hear a rattle that sort of sounds like a rod knock. This car does have a lot of miles but runs great. No smoke, no check engine light. Put the car in drive or reverse and the rattle goes away. The noise is loudest on the passenger side and sounded like it could have been coming from the water pump. After timing belt and water pump, no change in the noise. Took to exhaust shop thinking catalytic converter issue because there is a stumble at light throttle, and it is not exhaust related. Not sure what else to do. Took to a mechanic and they told me they could not find a problem.
Jun 3, 2018 at 11:48 AM
