Hey everybody. Hope you can help me out. Had a thermostat go out about a month ago. No heat and no reading on temperature gauge. Replaced that and got my heat back but now....
Truck runs fine at idle. Normal gauge position. Piston software shows steady 260 degree CHT. When I take it out on the highway the CHT will steadily rise until about 290. The temperature gauge jumps to the red. When I pull over and check..there's no boiling. Top hose is really hot but I can still touch. After restart the gauge is in normal range again with the ECT back around 260. It repeats the cycle after a few miles.
Mechanic I checked with said radiator but also checked for a head gasket. His test turned out negative though.
I changed the radiator and bleed the system but the problem remains.
Notes: It did this twice before about 6 months before the thermostat was replaced but I was pulling a huge hill and figured that was why. Never thought about it again until it started doing it all the time.
Aftermarket radiator had a filler neck. So I have both a 16lb radiator cap and a 16lb expansion tank cap now.
No coolant loss has been noticed.
Check engine light does throw a code for ECT circuit.
Any ideas are greatly appreciated. Thanks
Jan 26, 2020 at 2:29 PM
